Hi all, Im a 40k player trying out Seraphon in AoS and i have quite a few models but not sure how to make a good list. Below is a list of models i have. If you wouldnt mind could you help me do up a list from the below into something decent? If you could recommend purchases if needed that would be great Slann priest Skink priest Scar veteran on coldone 40 saurus warriors 20 temple guard 24 skinks Bastiladon with crystal Engine of the gods 15 knights on cold ones Cheers chaps Johno
Point level? also things might change later this month when AOS2 lands, but defo pick up a SC box it's too good not too. Where are you based?
In that case you need more core troops be it warriors, skinks. What do you want from the list, big dinos etc? Also budget £$
Welcome! I see a few options there for ~1k I think: 1. Firelance based list with Basti as fire support - 15x Knights, - ScarVet on Cold One, - Bastiladon, - Skink Priest or Starpriest => 130 points to spare 2. Eternal Starhost if you get an Eternity Warden I recommend the following two things: - Check out Warscroll builder, it is a great tool to play around with the points and build some lists: https://www.warhammer-community.com/warscroll-builder/ - wait for the new rules to drop
